582901 Mensajes en 146513 Temas por 48829 Usuarios - Dale la bienvenida a: starmanmdq --- Principal --- Agosto 24, 2016, 01:16:41
Total de Usuarios: 48829
Anteriores: starmanmdq
Total de Mensajes: 582901
Total de Temas: 146513
Conectados hoy: 57
Usuario: 8
Visitantes: 32
Total: 43
Autor Tema: NECESITO URGENTE EL MODO DE RESET O SERVICIO DE CYBERHOME  (Leído 6229 veces)
david hernandez
DT$ 1309
Edad: 49
Profesión o Título: tecnico
País: el salvador
« Respuesta #3 en: Abril 06, 2008, 15:56:42 »
colega  wilrey ya probastes de eta forma ( Abrir y cerrar la bandeja con la tecla del panel, oprimir STOP por 6 segundos)o tanvien puedes probar con cualquiera de estos .
CyberHome AD-L528
Turn on the player
Open the tray
Press Stop
Enter 1, 9, 9, 9
CyberHome AD-N212
Press the Open button on the Remote Control to open the drive tray
Press the 7 button on the Remote control
Press the 6 button again on the Remote control
Press the SEL button on your Remote control
Cyberhome AD-N515
Press Open button on the remote control to open the drive tray
Press 7.
Press 6.
Press SEL.
You should now enter a hidden setup page.
Select a Country code 13 for region free.
This setup may not work on all versions of firmware. Note that the newer Cyberhome AD-M512 model doesn't appear to support this setup.
CyberHome AD-M 212
Power DVD on with no disc in
Press 7 6 on remote
Then press Select
Takes you to the service menu
Then select region 13 for multi region
Next page has macrovision
Set to 0 to disable it.
CyberHome AD-N512
Cyberhome CH-DVD-300
1.  Ensure the players disk tray is Closed with no disc .
2.  Press Menu.
3.  Press 1.
4.  Press 9.
5.  A menu will appear with the region number near the bottom of the screen.
6.  Press Enter.
7.  Select the desired region.
8.  Press Enter to save the settings.
CyberHome CH-DVD 302
Switch the player on and open the tray
Press "Stop"
Enter "1999" with the remote control
Select "Region-Code" using the remote control
Press the "Enter" button on your remote control
Change the setting to "All"
Confirm this with the "Enter" button
Close tray with the remote control.
Cyberhome CH-DVD-400
1.  Turn on the player.
2.  Press Setup.
3.  Enter 1, 3, 6, 9.
4.  Press 3 x Left.
5.  Press 1 x Right.
6.  A new entry appears in the setup menu, called "Version" there, you can change the region code with the Up and Down arrows.
7.  Changing this value to "0" sets the player region free.
CyberHome CH-DVD 402
Player "on"
Open tray
Press "setup” button
Press 1,3,6,9 on your remote control
Press left cursor 3 times
Press right cursor once
New tab appears "Version"
Select "Version"
Go to "region code"
Cursor left
Change region code to 0.
If  code doesn't work, see "PARENTAL".
(setup / general / parental)
If "8:OFF" is selected, change to another one
(e.g  "2 : G") (Password is "1369").
Cyberhome CH-DVD-405
2.  Press Setup.
4.  Press 3 x Left.
5.  Press 1 x Right.
Cyberhome CH-DVD-500
2.  Open the tray.
3.  Press Stop.
4.  Enter 1, 9, 9, 9 in order, and one at a time.
5.  You should now be in a hidden menu.  You can change region code to all, but not disable Macrovision.
Cyberhome CH LVD-702
2.  Open the tray.
3.  Press Stop.
Cyberhome CH LVD-712
2.  Open the tray.
3.  Press Stop.
Cyberhome MP016-A:
1.  Ensure the players disk tray is Closed with no disc.
2.  Power on the player.
3.  Press Stop.
4.  Enter 4, 4, 0, 8.
5.  You should now be in a hidden menu, set the region code to 0 for region free.
es pero te sirba  alguno de estos.
suerte.....
El link de este tema es: http://www.dtforum.info/index.php?topic=45114.0
David  Hernandez
saludos: desde el salvador c.a
wilrey
DT$ 532
Edad: 46
Profesión o Título: ing tecnico telecomunicaciones
« Respuesta #2 en: Marzo 15, 2008, 15:08:53 »
YA LO HICE PERO NADA POR ESTO NECESITO
HACERLE RESET PERO NO TENGO EL MODO
DE SERVICIO
SI LO SABES TE LO AGRADECERIA
coquito
DT$ 1098
País: venezuela
« Respuesta #1 en: Marzo 15, 2008, 15:05:07 »
sale distorcionado por que esta en el modo de progresive scan si logras ver algo metete en el menu de configuracion
wilrey
DT$ 532
Edad: 46
« en: Marzo 15, 2008, 14:56:41 »
TENGO UN DVD PORTATIL M CYBERHOME
AL CUAL EL VIDEO SALE DISTORCIONADO POR
SALIDA COMPUESTA PERO EN EL LCD SE VE CORRECTAMENTE
SI ALGUIEN TINE MODO DE SERVICIO O RESET
SE LO AGRADECERIA............
Julio 02, 2016, 12:29:57
