mayo 24, 2019, 23:11:05 pm
medidor de gauss
Visitante · 7393
AntenA
on: febrero 13, 2007, 00:51:46 am
Hola !! alguno tendria informacion para fabricar un medidor de GAUSS o de imanes permanentes ,que lea de 0  a  1000 gauss  ,, o donde se puede comprar aca en buenos aires argentina ,,pero si me pasan un circuito mejor,,gracias,,
                                                       AntenA
Desconectado zoco
  • Reparador desde 1962
    • DT$ 1030
  • ZOCO-۩۞۩
hector27
Respuesta #2 on: febrero 13, 2007, 08:23:14 am
AntenA
Respuesta #4 on: febrero 13, 2007, 14:11:05 pm
gracias Zocotroco,, es algo sencillo ,,pensaba en algo mas elaborado que me diera la lectura en un display luminoso directamente ,,pero creo que esta bien como para emprender algo mas elaborado ,,capaz que acomodandolo un poco lo logro,,gracias igual,, graciassss
                                                AntenA
Pd: la base esta,,,,jajajjja
Desconectado zoco
    • DT$ 1030
  • ZOCO-۩۞۩
Respuesta #5 on: febrero 13, 2007, 15:50:52 pm
Hola, mira agrego algunos articulos mas
este en particular
http://www.pureenergysystems.com/os/MagneticMotors/BMM/plans/gauss_meter/make_inexpensive/index.html
relata la forma en que mediamos los imanes nosotros alla por los 70
Cita
recommend this method.
It can be calibrated with a good oscilloscope and a coil of wire and a sizeable bar magnet.  The face of the magnet with the flux eminating from it should be bigger than the coil to be swept over the surface.  Uniform motion by your hand is key to a decent calibration.  The exact speed of your hand is unimportant.  Use the scope to view the voltage from the thin coil.  I recommend just a 10 turn coil of enameled wire 1/2" in diameter.  Sweep it over the face of the magnet, even starting and ending the motion beyond the magnet.  You will see a rounded pulse waveform, almost squared off.  The time of the pulse and the length of the magnet face crossed tells you the speed of motion.  By the number of turns and the peak voltage that is somewhat constant, you can calculate the number of flux lines crossed.  I do not have the equations handy, but have done this in the past.  10% error is a halfway decent calibration for B flux of the magnet face.
aqui hay otro
http://www.rcgroups.com/forums/showthread.php?t=307133
saca el sensor de un mototr de reproductor de cdrom
este esta traducido y tiene algunos errores pero se entiende
http://64.233.179.104/translate_c?hl=es&ie=UTF-8&oe=UTF-8&langpair=en%7Ces&u=http://my.execpc.com/~rhoadley/magmeter.htm&prev=/language_tools
puedes usar el google  para traducir si no te  entendes con el ingles.
